Long shaft to short shaft Mercury 1150 conversion?
kungpaoshizi
I've been looking around for info, but everyone seems to want to go from short shaft to long shaft.. :rolleyes:
I saw a post on here about a Mercury 800, it has the same midsection, different gears (to warrant a prop change), and a few slightly different components elsewhere.
Is there other models to consider as well that are compatible with a '77 1150, perhaps without a gear difference?
Is a short shaft even advisable for a 1150, or just a medium shaft because of speed differences or something?
Mi duckdown
Re: Long shaft to short shaft Mercury 1150 conversion?
It all depends on the BOAT height transom you have. 15" short, 20" long.
matt167
short shaft 6cyls do exist but not many. You could use a 65-85hp short shaft 4cyl midsection and other parts. Gear ratio is 2.3:1 for the 4 and 2.0:1 for the 6. It will never run full potential with the lower ratio. If you want 115hp on a 15" transom, get a jack plate
Chris1956
Kung, I had thought your transom was 20". There are not many boats rated for 115HP that have 15" transoms.
Chris1956
If you hang a 15" shaft motor on that boat, you will not get on plane.....
Faztbullet
Kung the dealership I worked for in 1979 sold Venture bass boats and you need a standard 20" motor. That boat with a 4 "jack plate( 6" reversed) with a 20 Turbo ran in the high 40's -low 50's depending on load.
