Re: Long Shaft/ Transom Height?
You might test it out on the boat, and check out the performance. Weight is probably not an issue, provided the transom is in good shape (You can stiffen it a little, by the way, if you put a metal plate under the transom screws on the inside.) I think you might not be able to get on plane, and the torque in trying unsuccessfully to do so will put additional stress on the transom --so be careful. If you want to use the boat at slower speeds, the longer shaft length will probably not be a hinderance -- and in the meantime you can think about ways to mount the motor higher (or look around for a short shaft to fit the motor). The older motors have a 5" extension in the leg that provides the longer length. In these motors, you take out the extension to make a short shaft -- provided you have a shorter driveshaft that will work. On some that I have, I convert to a short shaft by simply bolting up a spare lower unit with its drive shaft in place (which is how you would normally purchase a used lower unit).
