Long to Short 1957 35Hp Johnson RDE-19M
Capt. Steelhead
Hello again this is the captain, sorry, I just had to do it. Anyway I was using the search and saw that some times you have to remove the power head for conversion Is this true with my motor going to a long shaft.couple questions what is involved here I'm buying a book probably Seloc shortly so I'll know more. What things should I look for when buying used long shaft components?
WillyBWright
Re: Long to Short 1957 35Hp Johnson RDE-19M
Here's what you'll need:<br /><br />Exhaust housing extension<br />Longshaft drive shaft<br />Shiftshaft extension and link or longshaft length shiftshaft<br />Water pipe extension(s) (2?) or longshaft length pipe(s)<br />Long 3/8 bolt<br />Exhaust housing mounting bolts (6?) (same size as the ones you already have)<br /><br />The exhaust housing extension is also critical. There are two possibilities for 35s, but only one for a 1957. Newer models won't fit. You can look for parts from a 25, 30, 35, and 40 (although the 40 would have the wrong exhaust housing extension). You can get these from Johnsons, Evinrudes, Sea Kings, Gales, a few others.<br /><br />The parts are pretty straightforward. Beware of worn bearing and seal surfaces on the driveshaft, as well as worn splines. Might as well buy a new impeller as long as you're in there. Good luck. If you find a used or junked longshaft it should have everything you need.
rolmops
You don't have to take off the powerhead,there are different ways to extend the shift rod.<br />When I did mine I extended the rod part that comes out of the lower unit.<br />It is VERY important to use an o-ring between the cooling water pipe and the extension.If you dont use it, you will look at a ruined powerhead in half a year.<br />Come to think of it,I have a complete extended lower unit in my garage.If you are interested write me at "dharrin1@rochester.rr.com"
