Those were good motors.
Most people bypass the VRO system and use premix gas.
Compression test on the motor before you buy it!![]()
I'm not familiar with outboards at all. Is this motor any good, and is there anything I should check or watch for?
He said he replaced the VRO pump to a VRO2 pump.....not sure what this means.
Thanks
There is a difference between the three similar OMC/BRP oil mixing fuel pumps: VRO, VRO2 and OMS (oil metering system). They all work very similarly, but the OMS is the latest version. They vary in the alarms they have or don't have and the actual ratios of oil-gasoline at various rpms. Everything I've read says both the VRO2 and OMS systems worked very well, but the original VRO not only would be very old, but doesn't have a full complement of alarm systems.
If that engine is a 1990, it originally came with a VRO2 pump, so when he said "he replaced the VRO pump to a VRO2 pump", it doesn't really make sense. Better to know how old the "new" pump is and how well it works - including the alarms. I'm not sure of the dates, but I think any pump purchased in the last 10 years or so would be an OMS.
You can find more info on this at: http://continuouswave.com/whaler/reference/VRO.html
"most"? really? Not in my experience. "Some" yes - and no problem with that. But my experience is that "most" leave the system intact and have troublefree use with normal system maintenance.
I hate for newbys to get the wrong impression about these systems - see above link.
Bayliners of the vintage don't have the best Reputation, but 99% of that reputation was bad owners. lack of proper maintenance.
Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame. You walk all over the deck, that a mallot, or hammer with wooden handle, using handle, tap all over the transom, a shape rap is good solid base, a thud, is questionable base.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. (This part for outboard motors Compression should be atleast 100psi, and within 10% of each other,)
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
boat motor combo, A 30 year old may be in better condition, than a 3 year old.
