Re: Looking at a motor for sale, Has power tilt but no trim
Tilt has an override valve that releases when pressure gets excessive regardless of whether or not it also has trim.
Like a PTT unit has about 20 or so degrees of trim tucked inside 40 or so degrees of tilt. If you have the engine outside the trim range and goose it, it will pressure relieve back to the nearest trim spot. However, if you are at low rpm's it will go the full tilt range and hold it.
About all your trim will do for you is to tilt the engine up while you're polling across the flat.
