Looking For 1990 90HP L Drive Crankshaft
jeff9377
Does anyone know where I can get a used or new crank shaft for a 3 cyl 1990 90hp L drive. I had my trim to high in rough water and bent the u joint drive shaft which in return blew out all the housing around it, busted the drive shaft and gears in my lower unit, which I might add I just rebuilt in 2004. And I think I either striped the threads or busted the crank at the engine. Im hopeing it is just the lower and middle unit because I already found and purchased these parts from a guy parting out a 1989 Bayliner with 120 hp L drive with a broken powerhead (let me know if you need his number for other parts) Thanks to all that reply
CharlieB
Re: Looking For 1990 90HP L Drive Crankshaft
Call Dan at Outboard Crankshaft, Lynnwood, WA 425 744-0626
I have a 90 Maxum 120 L-drive w/ smoked #1 journal
Customer could not afford the job and it has set here for over a yr, I should be filing paper soon and willing to listen to reasonable offers.
