Looking for 40/50/60hp mercury gears!
tyst67
I'm looking for a set of second hand gears for 1997-2006 40/50/60hp mercury! They have to be 1.83 gear ratio
Fun Times
Hi there, I know your intention is to try and save some extra money by looking around for a used gear set but unfortunately iboats doesn't permit any sort of solicitation on open forums so about the best we can do at this point is try looking up your OEM part numbers then do an online search for them.
It looks like your gear part numbers are 43-822163T1 GEAR, Reverse (22 Teeth) ,..., 43-822162T2 --GEAR, Forward (22 Teeth) and 43-822161T2 --GEAR, Pinion (12 Teeth)
Item numbers 9, 48, 58,
http://www.mercruiserparts.com/Show...+Housing,+Propeller+Shaft+-+1.83:1+Gear+Ratio
http://www.mercruiserparts.com/Show...c=Gear+Housing(Driveshaft)(1.83:1+Gear+Ratio)
Here's some used ones to consider for you,
http://www.ebay.com/itm/USED-MERCUR..._Accessories_Gear&hash=item416fdc16ca&vxp=mtr
http://www.ebay.com/itm/43-822163T-..._Accessories_Gear&hash=item5d52e2bba5&vxp=mtr
http://www.ebay.com/sch/sis.html?_n... 43 822162A2 43 822162T2&_itemId=331156845875
If not, the only other suggestion would be to try calling some Salvage Yards found in the link below.
http://forums.iboats.com/forum/engi...oards/449716-salvage-yards-by-wilde1?t=438822
Then in rare cases, keep an eye on your privet message to light up as you may get a response from some of iboats helpful forum members that may have something lying around the shop.;)
Hope this helps, good luck.:)
