Looking for 6 tooth spline prop for 1982 DT25VZ
mussie76
Hi All
A mate of mine is looking for a Prop for a 1982 DT25VZ.
He says that he can only find props for DT25's made after 1983 and all these props have 10 tooth splines, the 82 has a 6 tooth spline.
He has located an original prop but it is very expensive and I am wondering if anyone knows where we might be able to purchase an aftermarket prop for this motor.
Thanks
Re: Looking for 6 tooth spline prop for 1982 DT25VZ
Ayuh,...
Just for Us Uninformed,...
Maybe you could tell Us the Manufacturer of the DT25VZ,+ the DT25s...
I know alittle bit about Props, but DT25 means Nothing to me...
mussie76
Ayuh,...
Hi Bond-o the motor is Suzuki DT25VZ 1982 6 spline with ex through the propeller.We have checked out alot of after market ones and they can supply the 6 spline.I hope these details will help thanks for the reply.
I too am looking for a Suzuki DT25 Propeller and can only find it through special order from Suzuki. If anyone out there has even a hub that I could get rebuilt I.d be happy. The prop as you know is a 3 x 9 1/4 x 8 or 8 1/2 or 9 pitch. It is a unusual 6 spline hub and was made in 1981 and 82.
