Looking for a 19p 3 blade prop
mwinchel
Hey everyone i am looking for a cheap 19 pitch 3 blade prop for my boat. I have a 1971 mercury 1150 motor with threw hub exhaust it is 15 spline. If anyone has a extra one and want to get rid of it let me know thanks.
Re: Looking for a 19p 3 blade prop
Ayuh,.......
ebay is where you want to be Lookin'......
Besize,...... Soliciting is against the Rules of the forum......
The 15 spline props shafts are the same on most Merc.s right up thru the Bravo drives,.......
You need 1 for the 4" gearcase,...... I think they run up to about 13" overall dia....
Not the 4, 1/2" used on the Big Block Outboards,+ the Outdrives......
They run from about 14" to 15+".......
Either 1 of them will slide onto the shaft, but Nothing else lines up......
Good Luck,...........;)
Silvertip
As long as you found iBoats, go to the top of this page, click the "Marine Store" button, scroll down to Propellers and knock yourself out. Brand new props are available from 80 bucks on up. Can't beat that with a club.
