74FABUGLAS
- May 1, 2002
- 6
I am trying to clean up the wiring on a friends pontoon boat (55hp Yamaha). His fuel guage does not indicate when the ignition switch is set to "on", but it will indicate when the running lights are on. One thing has me stumped, I can't find a wire that is "switched" thru the ignition switch. Everything appears to be fed from the main bus through panel switches. Shouldn't there be a wire that goes hot when the ignition switch is turned on?
