Terry Olson
- Aug 20, 2005
- 415
I'm new to the site - and I can see there's plenty of traffic, experience, and expertise here.<br /><br />I just bought a 1983 Lund 18' side console boat (Mr. Pike model - 50 Mercury with power tilt - for those who might like to know). I plan to either repaint above the water line or simply remove the paint and leave it natural. I know this looks good on some boats but I have a hard time imagining it on my Lund because you never see them other than with the classic red over the water line finish. <br /><br />I have a couple of questions:<br /><br />First, does anyone have pics of a similar boat that has been sandblasted and left natural rather than painted? <br /><br />Second, I've done limited research and will buy a sandblaster for work on the trailer. According to what I've read there is no problem sandblasting an aluminum hull so long as I use aluminum oxide media and extra care to avoid eroding the material by using too much pressure or an overly aggressive technique. Is this correct? Is there a better option?<br /><br />Third, is the cheapie-made-in-Korea/China/wherever sandblaster which draws the media from a bucket through a hose suitable for the hull and trailer work? I know - you get what you pay for - but I've had good luck with the cheapie HVLP spray gun I bought as it is good enough for the limited use I put on it. <br /><br />Fourth, I'll be replacing the floors, which are original to the boat and a bit soft. With the advent of maintenance free decking materials - for houses I mean - I'm thinking there must be an alternative to plywood suitable for boat flooring that won't deteriorate over time. Any thoughts or ideas along these lines?<br /><br />Fifth, there are several places where accessories, cleats as an example, have been attached using what appears to be stainless steel screws. I've read that that dissimilar materials will result in electrolysis. Is this of great concern for a boat used exclusively in fresh water? If it is, what is the best way to attach these accessories? <br /><br />Sixth, (and related to my fifth question) there are several holes in the hull near the gunwale that I plan to either seal with new aluminum rivets or stainless steel fasteners. I was thinking that an option might be to run a self-tapping screw into the hole, then grind both sides of the hull flush. I'd probably only do so if I decide to paint the outside of the hull and carpet the inside so the repair would be reasonably concealed. Any thoughts about this method? <br /><br />Sorry to ask so many different questions in the same post. Thanks in advance for any responses you can offer. The boat doesn't need much and I plan to complete it as a winter project, but I'm so fired up to work on it that it'll probably be done before the new year arrives.<br /><br />Link for project: http://www.shareaproject.com/projectThumbs.php?p=129
