billysboat
- Apr 24, 2010
- 50
It started with this post http://forums.iboats.com/showthread.php?t=406334 and now I've switched to this forum.
!966 Champion speed boat
17' length
351 ford w
volvo outdrive gears unknown
wot 5000 rpm's ( suggested wot 42-4400 )
current prop 14x22 LH stainless 3 blade
....without going through a lot of expense of trying different props it now seems I can use a prop change. It appears and what some friends are telling me I can increase the diameter of my prop. the clearance between the prop and the unit itself is about an inch or slightly more. What will happen if I increase the diameter only keeping the same pitch ? And by how much would a difference.
Or should I just change the pitch? From what I have noticed and having a 22 pitch already, would a 24 be a good choice?
I am looking forward to your suggestions or comments. Thanks
17' length
351 ford w
