Looking for HELP for more speed ,power & RPM
SouthernWolf
:confused: :confused: :confused: :confused: <br />I have a 1987-195XLC Chapparal fiberglass hull with a OMC-4.3 & OMC-Cobra outdrive..With a 2 barrel Carb .The prop I'm running is a aluminium 15-1/2-15. At full throttle I'm tacking 4800 to 5000 rpm,,but only running about 35 to 38 MPH. or at least thats what the speedometer is showing, :confused: Could it be something wrong with the speedometer? I'm thinking my engine size and Carb size i should be running about 160 hp or little more,But should'nt my speed be better?? What should I do or what needs to be done,or am i in the wrong and my boat is running right :confused: :confused: <br /> THANKS
blifsey
Re: Looking for HELP for more speed ,power & RPM
Do you have access to handheld GPS (friend, etc.)? I would check speed with GPS first and go from there. Maybe someone here can tell you if that is proper RPM range for that motor.<br /><br />BL...
it looks like you need at least a 17" prop to lower you rpms.. the 4.3 is happiest at 44/ 4500rpm WOT.... your over reving it now...you maybe able to spin a 19" for a little better top speed,But your lowend power will drop off...
