looking for measurements for v/p sx-a trim pistons
stang32
i have a 2009 v/p and believe the trim pistons are not going to full extension and was hoping someone out there with the same setup could give me a measurement from center of pin to center of pin. i have 19 3/4" full extension. i really think this drive should be able to go up further. i pulled the pins and thedrive goes up plenty more than full travel is right now so it make no sense that this drive only goes up this much.
dypcdiver
Cannot really help as mine is a DP-SM and full extension is 55cm or 21&5/8".
However you may have trim limiters within the cylinders, see photo.
stang32
good point, i ma have to pull this apart and see if it has a limiter.
