Looking For Pair of 17" Louvered Vents
Jacalore
Looking For Pair of 17" Louvered Vents. 2-1/2" wide. For older Chris-Craft.
There're around, just not too available. Chrome preferred, but would look at other options (ss, plastic).
Anyone have a link or tip where I might locate a pair? Thanks.
Jacalore
Re: Looking For Pair of 17" Louvered Vents
Thanks for the link. Close, but no match. That's the problem I'm running into...
I need 17" x 2.5" louvered 7-vent vent with two screw holes at each end.
Ideally, I find drop in replacements, without modification. Any help appreciated. Thanks.
Is that measurement for the overall size of the vent, or the size of the cutout??
Jacalore
Some carver boats use a 17 1/4 x 2 1/2 vent. Might fit ( depends on cutout size )
I'll have to pull the vents, take measurements of cutout. May be that I'll have to modify something to fit. Thanks.
Jacalore
Wanted: Louvered Vents
Outside dimensions: 17 x 2.5
Cutout dimensions: 15.5 x 2
Jacalore
That would definitely fit. More screw holes, but that's doable... I wonder if this design would pull exhaust from engine compartment, tho, like an louvered vent would?
I wondered that too. I think air moving over any opening will have a suction effect - but how efficient any vent is will depend on many factors anyway ( hull design, speed, wind direction etc ).
Jacalore
One difference is that with the louvered vents facing aft, no air enters moving forward, so it's always in exhaust mode.
