looking for prop recommendations
legoman67
Well, My dad restored a 1973 Searay SRV 220. It has a Merc outdrive and ford 302(originals). It had no prop on it when we got it, and now we are trying to find the best match for it. Any recommendations?
hwsiii
Re: looking for prop recommendations
Lego, welcome to Iboats prop forum and we will try to help you as much as we can but without more information no one can help you, and I will tell you I need more information than anyone else. But if you would like my help fill this form out and I will help you as much as I can, if you would prefer to not go to this much trouble there are other people who will gladly help you.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the maximum recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make. manufacturer and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape a c ross the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM ___________ Speed ___________ No. of people ____________ Gas ________
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
legoman67
best i can from the top of my head. ill see if i can dig up afew more awnsers
1. posted above
2. 22.5 hull length, 25 overall
2a. Stock 302 ford, whatever that puts out..
3. 4 people, 150 liters
4. cruising about, sight seeing
5. Deep vee, no idea
6. 1972 ford 302 smallblock
7. no idea
8. discontinued boat, no specs availible
9. no idea
10. N/A
11. trim tabs
12. none that work well currently
13. N/A
14. sea level(boat is on the ocean)
15. motor is a fresh rebuild, professionally tuned
16. about 2 hours of use, mechanic threw it on for us to test boat
17. minor, ^
18. better handling
19. N/A
Ayuh,... Throw a 19" prop on it,+ Try it....
Atleast you'll have a Baseline,+ maybe a spare prop...
scottishwarrior
I have a Quicksilver Power 2 Propeller (with complete set of instructions) I used on my 22' Cal Glass with a 165 hp stern drive. It's a 19 Pitch which switches depending on how you set it up. It acts just like an auto transmission in a car. It gives great starting acceleration, then drops the RPM's once you get up to speed. Let me know if you're interested.
legoman67
Thanks guys. Well i contacted Sea Ray, and they told me that the boat was originally equipt with a 14 x 17 prop. thats alot smaller then i was thinking. I guess we will start with that and that should be a good base point.
coastalcruiser
When my 23' boat had the 302-888 Mercruncher 188 hp, I was using a 19X19 prop
my wot was 4200 rpms
Hey whats the fishing like up at nanoose? I got a coho today and a red snapper over @ 5 fingers
legoman67
dont think a 19" would fit without hitting the leg itself... Theres a 15" i think on there right now, and its pretty tight...
fishing has been crappy for the last little while. Just today i heard that french creek is hot but i was too busy dealing with a sailboat that ran out of deisel when the guy told me, so i didnt really get any details... French Creek is only like a 20 min boat ride from Schooner Cove....
