Re: Looking for steering arm replacement thread or help.
1: You need to remove the gear case to get rid of the shift rod going through.
2: You need to remove the lower rubbermount holding the bracket to the leg.
3: You will need quite some HEAT to get the screws loose, which probably may ruin the upper mount,which again means removing the powerhead to change.
4: You need a hoist to hold the powerhead and leg if you manage to get the screws loose.
Bottom line, probably bigger job than changing pistons!!
