Re: Looking for various Online Marine Supply Stores
See you've already figured out Where to start looking....<br /><br />Power goes from the switch, to the gauge, to the sender, to ground......<br /><br />If there's power at the + on the gauge, Ground out the - on the gauge,+ the gauge will go to full....<br />Then Check the wire going to the tank.....<br />You'll need an ohm meter to check the sending unit....<br />But, Most Important of All is the Ground Wire from the sending unit to Ground.....<br />Good Luck...
