Re: Looking for your 2 cents. Old dry wood or Fresh new cut pieces?
Good decision going with new. If you're using Poly you need to use CSM mat, before applying any cloth if you want it to be strong and correct. With epoxy you only need cloth. when you use the mat, physically Tear the mat at the edges so they will be "Hairy". this will make it relatively easy to wrap the glass around the edges as it should be. Make sure the edges don't have any voids. It there are, fill them before applying the mat. Rounding the edges of the wood with a router really helps you when trying to wrap the edges.
