artificialreef
- Feb 21, 2009
- 504
Hello folks. Little disappointed in myself. Went to check my rocker clearance on a 1983 merc 470 which requires the use of the feeler gauge and collapsing the lifters in a specific sequence. I found the #3 intake lifter not pumping up so am accessing the cover to replace. When i removed the rocker i found the pushrod bent. While it is at #4 tdc i decided to look at #2 and #4 exhaust in the sequence. Both bent also. I am assuming i did this collapsing the lifters. When i horsed on them with the tool i felt resistance then it gave way. I thought that felt a little strange.
I guess i have 3 questions.
1. I think i collapsed (and probably bent the pushrods)the lifters and then ran it on the muffs for a few minutes because i was going to just change a pushrod but changed direction and went after the lifter. (had to run it to figure out which lifter) Nothing sounded any different. Still the one bad one clacking. Did i do any damage to the motor running with those other pushrods bent?
2. When i found the 3 bent pushrods i removed them waiting on parts delivery. Can i rotate 360 degrees by hand to check the remaining since the first sequence of rods are out and the corresponding valves will not open to hit the cylinders?
3. There are 4 different length pushrods shown in the manual. Which ones are the stock ones and what combination of rods do you folks purchase to get a motor back together? Maybe 8 of the stock and a couple each of the others?
part numbers 67502-3 through 67502-6
Thank you for your help.
I am going to punch myself i the face if i find all the rods bent. I swear i did it in the right sequence. This is my worst nightmare. Screwing up the motor chasing a tapping noise.
