- Mar 8, 2009
- 42,892
Story:
From my previous thread I had an issue with my Bravo 3 making some noise. The shop found that the top race was not installed correctly. They gave it back to me saying it was filled up a ready to go. I noticed some red oil so I loosened the bottom plug and red oil was present. Found out it was filled with 80W-90 Aqua Lube and is not synthetic. So I drained the lube and pumped in Merc stuff. Drained the Aqua stuff in a jug to recycle the next day. In the bottom of my drain pan I found a hole lot of metal shavings. Went back to the shop and was told, they flushed it out with carb cleaner and CRC but did not take the lower section apart. This is why I wind up doing everything myself, you just cannot find quality work. :frusty:
The shop did separate the two halves and take the top apart to fix the original issue. Shop said they did check back lash on the lower section and all was within spec and felt good.
Question:
Since I don't have all the tools "yet" I will need to completely overhaul the drive; do you think I can separate the two halves and flush it out with diesel? I'm hoping all of the big pieces have been found, or if any are left the flushing will work.
Question:
