Re: LOOP CHARGED ?
A loop charged engine refers to the method the fuel introduced into the cylinder. The fuel is directed into the cylinder in such a way <br />(porting) that it pushes the remaining exhaust fumes out of the combustion chamber with out the aid of a crowned piston . In a loop charged engine the piston is flat on top, unlike a typical 2 stroke piston that has a tall crown. The main advantages are, the downward force of the expanding hot gasses during combustion are not deflected towards the cylinder walls but instead push squarely on to the piston. A compairable piston also weighs less in a looper.
