Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
1981 galaxy 165 L6 chevy motor 165merc outdrive 1978, when prop nut is tightened prop will still move on shaft about 1/4 inch, spacer is in place , is this normal or is this a start of something serious .
When you say spacer are you refering to the thrust washer behind the prop? there should be both the thrust washer and also a washer under the prop nut, sounds like your missing something I don't think that prop should move.
yes the thrust washer and the one behind the prop nut are in place, could this have started when i fist took the prop off and put it back on without the thrust washer and it wore down my prop before i remebered why it was making a weird noise, like metal on metal .
How long did you run it without the thrust washer in it. A 1/4" is a bunch of metal to eat away. When you look behind the thrust washer does it look like there is a worn away area where the prop was pushing against the lower gear box.
ran it about 2 hrs total in 3 tripps to river. its not a stainless steel prop so the gear box should not be damaged should it ? only the prop should be worn down right ? and if so should i replace it and that should solve my problem ? i hope . thanks
