Loose Spark Plugs cause high idle?
I was warming up my motor this morning for a compression check and after about 3 mins of running it started to rev up really high so I shut it off. I waited a few mins and started it back up and it did it again. I decided to go ahead and check the compression and found 2 of the spark plugs were really loose. Would this cause the engine to act this way?<br /><br />Also, does anyone know the difference in the 3 model #'s for a 1978 115HP Evinrude? Someone painted over the tag and then it looks like the paint was scraped off, but part of the # was faded and/or scraped off with it. Is there any other way to figure out the model of this motor?
JB
Re: Loose Spark Plugs cause high idle?
Did you open the fuel tank vent, HFF?<br /><br />It is acting like it is running out of fuel.
DHPMARINE
What happened when you tightened the two plugs and ran it again ?<br /><br />DHP
I'm sure the tank was vented because I bought the gas today and by the time I had it home gas was coming out of the fitting because of the pressure. I loosened the cap and heard the pressure release and left it cracked so it could breathe.<br /><br />After I did the compression test I started her back up with the tightened plugs and it idled on the muffs for 10 mins without ever idling up like before.
OBJ
Where the plugs lose enough to suck in air? Be the same as leaning out the mixture.
I'm pretty sure they were loose enough to let air in. I noticed them because there was oil/fuel coming out of the plug holes and running down the block. I could turn them 1/4 to 1/2 turn by hand before they tightened up.
reeldutch
so how did your compression test turn out??
OBJ
That ain't bad.
