loose steering in my sea ray seville 1987. rack and pinion steering single cable
ernieoday
Loose steering in my sea ray seville. Replace everything from the steering wheel too the steering arm. From the steering arm to the gimbal is all good and tight. Actuator flats are vertical. Bleed the system. Any ideas
Ayuh,.... Welcome Aboard,..... Where is the steerin' loose,..??
If you've replaced everything, Where's the slop at,..??
