I have a'99 chaparral 180 with the 3.0 liter mercruiser. It has the power steering and tilt wheel. There is about 60 degrees of "play" at the wheel. It is the same whether the boat is running or not (engine on or off) or whether at idle or top speed. I have removed the cable protector at the helm unit, and there seems to be some play there but I cant tell if the problem is all in the helm unit, or a combination of the tilt mechanism, the helm unit, and the rack. I have not been able to remove the cable from the rear rack unit because when I try to remove the nut, the flange on the rack also turns with it..Any info would be appreciated-I dont want to just start replacing parts. My mechanic insists that the problem should go away under power, but this is nto true. When in forward motion at idle, the boat wanders back and forth and will not travel in a straight line-I suspect it is because of this issue.. thanks
