loosing lower unit grease from Sea King 6 HP
fishnpro03
loosing lower unit grease from Sea King 6 HP. It is coming from a hole that is made into the side right above the cavatation plate. i dont know if it is an over flow or if a seal is messed up. Otherwise the motor runs well. It is a 68 model. Any help would be appreciated.
S.T. Marine
Re: loosing lower unit grease from Sea King 6 HP
Is it leaking out of a screw hole? be more specific
Wingnutt
Check and make sure the hole is not threaded. That is the general location of the shift linkage pivot. There should be a slot head machine screw there. DO NOT REMOVE THIS BOLT!!!! If you do you WILL be taking the lower unit (foot) apart to get everything lined back up. :eek: Ask me how I know. :D
