spacemanpete
- Jul 7, 2003
- 49
Alright, if all goes as planned, there's a wiring diagram below for a Volvo-Penta AQ80. I'm not very electrically-inclined, so I'm having trouble wrapping my head around some things I know you folks can help me with:<br /><br />A) I'm assuming wire 1 (on the left side of the terminal board) is the main hot, and the #2, next to it is the main ground -- is this correct?<br /><br />B) wire #4 connects to the coil; on the other side of the terminal board, it splits off into three wires -- one to temp. gauge, one to tach, and one to ignition lock switch. What is going on here? Electricity is flowing, when the switch is flipped, from the switch -- but then does it go to the tach, temp gauge and through the term board to the coil?<br /><br />C)As you can see, the engine has a generator. How is the energy it is creating getting back to the battery? Through which wires? Please explain what the energy in the two wires connecting to the generator are doing.<br /><br />D)Lastly I want to change the ignition lock/button to an igition switch. If I do this, wire #1 would go on battery, but which ones would go on "I" and which on "S"?<br /><br />Lots of questions -- thanks for your help -- I can only stare at this thing for so long . . .<br />
