loss of drive 45hp chrysler
kiwichrysler
having problem, engine goes into gear and will drive at idle speed but will lose drive totaly on aceleration?<br />gear box has been checked all gears and clutches linkages and correctly adjusted and are in good order.
steelespike
Re: loss of drive 45hp chrysler
You may have a spun hub on the prop.<br /> A prop shop can usually fix it.You can check <br />it by marking across the hub a check the mark after running the motor.
kiwichrysler
SHEAR PIN IS PERFECT. PROP SEEMS TO BE ROCK SOLID<br />AS IT SEEM'S TO BE A SINGLE PIECE ITEM?
