Loss of engine power
dmoss
I have a 2001 90 horse Mercury. Going across the lake at 4300 rpm for 10 minutes and then suddenly lose power and at full throttle will only turn 3000 rpm. Will start and idle but roughly. When you try full throttle it won't die but when I pulled the air cover off the carbs, there was gas laying in the bottom and everything was wet with gasoline. Any suggestions??
dmessy
Re: Loss of engine power
Check spark and compression..may have dropped a cylinder
