Loss of power finally solved
robr229
I have had my boat for nine years now and brought it new in 2005 the last 3 years I have been struggling with intermittent loss of power and slow up on plain was at the point of just having my boat as a floating hotel and never taking it anywhere . So after throwing part after part at this problem I spent about 3 weeks researching this reading many blogs and and posts on this site .. First lets me say what I have done cap rotor wires plugs and a costly wineing fuel pump (900.00) so I thought for sure this would solve the problem but like I said this was always a intermittenting problem the boat ran great two times out and then the third time same problem again no power and difficulty getting up on plain max RPM 3800 then I came across a posting on this site about the fuel pressure regulator TSB from Volvo to remove the screen and replace it with eclip
So I did this and noticed a slight increase in horsepower and engine seemed to respond slightly better to a snap of the throttle while in neutral, since I was now determined to finally solve this problem I took it a step further and remove fuel rail and injectors after looking at the and searching youtube videos on how to clean the injectors myself i changed my mind and set them to south shore injectors in Rockville center New York for 20.00 an injector they were professionally reconditioned and much cheaper than buying new ones well I picked them up today and after speaking with the guy 3 of my injectors were clogged up and we're not producing enough fuel to the engine so guys don't waste your money on cleaner you dump into your tank hoping for a miracle like I did . That is only for preventive maintenance , while working on the boat today I had picked up some electrical spray cleaner that dissolves corrosion on the connectors and the pins inside the connectors I never new there was such a product and followed up with electrical grease I did find many connectors that were in very bad shape
And did this to the connections that didn't need it. Boat now runs perfect max rpm now 5500 boat jumps right up and plains right out hope this helps oh btw pay special attention to to lower connector on the fuel cell if there is any corrosion on that connector the fuel pump will not supply enough fuel to the engine and boat will have loss of power
Re: Loss of power finally solved
Ayuh,.... Welcome Aboard,..... Neither do I,.... What is it,..??
Donno what yer motor is, but I'm guessin' 5500 rpms is well Over the recommended Wot rpms,...
robr229
Glaston gs249 2005 took it out again today rran great yes 5500 well over recommended I usually cruise at. 3800 rpm but it's a good feeling to know that you have more power if u need it
bruceb58
If you are really able to run 5500RPM, you are way underpropped. Do not know what engine you have as you don't state what it is but I would read your operators manual and never exceed the spec'd max. RPM
Ike-110722
Ask any electrician or electronics technician and they will tell you this stuff has been around for years. Contact cleaner helps to get the crude off of electrical connectors. Over time a type of varnish builds up. On most connectors it looks brown or even darker. This stuff helps to get it off. But the best way is to disconnect and use a fine grit sandpaper. Actually I use my wife's finger nail buffer. Works great.
Dielectric grease is a very light grade grease that is also conductive, but seals out any moisture. it is particularly good for those butt joint wire splices. Just squirt it in and the put the wires in and crimp. I also wipe it on ring terminals and other connectors.
You can get both in the electrical section at most hardware stores, radio shack, Maany marine stores, or any electrical supply store.
