1989 90 hp....today got to ramp,motor started right up,put in gear idle out from ramp then went to take off,no power,rmp's only make it to 2200,it netural motor will go all the way up,no problem.....test comp. got 110,110, 105, 100, out in the sun I can see a good blue spark.....last time run was last Tuesday and it ran great....fuel pump is only year old,rebuilt carbs about a year a go.......Is it time to pull carbs again or something else that I am not thinking of...hard to test sitting in the yard,motor idles fine.......
