1994 225TXRS 3.1L V76
I just lost 1000 RPM. Last weekend boat was running good up to 5300 RPM WOT with 19 pitch prop, went get back to dock engine started sneezing got home cleaned carbs. soaked in solution for about 1h put everything back adjust sync, adjust TPS .47v,adjust idle 725 RPM, adjust pilot screw 1 1/2 turn out, did compression test engine with normal temp 105 psi in all cylinder, replaced fuel/water separator 10 micron, went for test drive engine ran smooth but when hit WOT max rpm 3800 when start to plane max RPM 4000 w/trim up 4300 RPM last week before everything happens WOT 5300. I change All fuel hoses and New fuel pump about 6 month ago.
About the compression test that is ok or is to low what is min or max for this engine.
I'm missing something any help or suggestions?
Thank you
Thank you
