muskyhunter
- Jul 9, 2007
- 5
Hi! I have a 1984 140 merc i/o. Everything was fine on the water for most of the day drift fishing but then I started the boat up again to make another drift I didn't have forward gear! Cable from shifter to the motor was good. The cable from the motor to the outdrive I'm not to sure because it moves and seems to move and can hear it trying to engage. So I thought I would check the shift couplers.After I pulled it out of the water of course...LOL. I noticed that the bell housing shift coupler was sitting on top of the drive unit shaft coupler not connected together like they should be. It is almost like the drive coupler is not high enough to sit up inside the bell housing coupler. When I lift up the drive coupler it will engage forward and reverse. Now can I replace the drive coupler/ lower shift cable or is it worse than that? ie:gears?
Thanks in advance for any info!!
