Lost Yamaha boat key
khoi30
Well I lost my only boat key to my 1997 yamaha 90hp engine. Can a lock smith make me one or a yamaha dealer can find me a spare key. Is there any code on the control box
that i can bring to the dealer where they can match it. If so where is it located.
Thanks
99yam40
Re: Lost Yamaha boat key
The switch should have a number on it if you look closely and the dealer can get you a key
rodbolt
unscew the plastic nut holding the switch in place, you will see two flats.
the key number is on one of the flats.
from there any yamaha dealer can supply one for about 5 dollars.
if someone actually did the PDI sheet and it was correctly registered it will show up on the yamaha dealer website as well.
type in the PID and if the pre delivery inspection sheet was actually done correctly the key number is on the sheet.
