SSTKO81
- Jun 1, 2009
- 347
I'm going to enclose plenty of pictures here soon so you'll see what I see. I'm trying to make sure all my Ts are crossed and i(s) dotted....
So the alternator I've got is a GM unit. The 4 wire system is now a 3. I've got the red and orange wires spliced together. That just leaves my ground and a purple wire that tests 15V w/ ignition on (12v when points are closed?) Up till now I've had that wire just capped but seems it should probably hook to one of the two spade terminals on the alternator. Which one?
Next, the coil tests 2.8Ohm across the terminals 15.83v on + side with points open,5.28 when closed. Negative side is 15.82 w/ points open .06 when closed.-sounds correct. However, I use an aftermarket Pertronix coil, which I think requires 12v; should I be bypassing the resistor wire so I get 12v?
Finally, I think buying a new cap is the short answer but It seems my dist. cap is getting chipped up at some points by the rotor. Is this normal?
I'm asking all this because I'm still chasing a no start issue. I'm still using my engine that's on its last leg as compression on 2 of the cylinders is only in the high 90s but should still fire and it's not
