Lots of oil in outdrive oil...reseal?
pktaske
I had water in my 1986 Alpha I drive oil so I pulled lower unit. Replaced water pump, shift shaft bushing and the little rubber gasket that sits between the upper and lower drive to see if that was the problem (relatively easy and and cheap). When apart, I noticed that the drive shaft seal in the upper unit didn't look too great.
Put it back together, refilled and ran for about 5 min. Noticed the next day a little bit of oil from the forward-most gear housing stud (was sitting overnight in full tilt up position). I lowered the unit and the next day saw oil (small amount) from bottom weep hole. Ran engine again. After I shut it off, and went back to check things out, a guzzle of oil and water were coming out of the prop hub. Figured this was bad so I drained oil and pulled the entire outdrive off. (note - this was my fist time doing this and the top unit didn't exactly "slide" right off. I had to jimmy it little by little. Took about ten minutes in all being very careful. Normal?)
Anyway, once it came off, a splash of oil came out and there was a pool of oil sitting in the u-joint bellows.
Prior to messing around with ANY of this I had no oil leaking from the outdrive at all - just milky oil. I tend to think I aggravated a problem up top when I pulled the bottom off the first time.
Does this sound like I just need the unit resealed? How could I go from milky oil to total failure like this? Thanks..
Haut Medoc
Re: Lots of oil in outdrive oil...reseal?
Welcome to iboats......:)
I'm guessin' that you installed somethng wrong (Seal).....
I would pressure test the drive & see where the leak is.....
You may need to split it in half to isolate the leak(s)......
Water & gear oil in the bellows means the yoke seal is bad....;).​
pktaske
you might be right...but the fact that there's oil in the u joint bellows means there's a problem up top anyway. I'm trying to find a good shop around here. A reseal is relatively cheap so I'd like to just bring it somewhere, watch and learn.
