rustyscrew
- Mar 29, 2006
- 141
Summary: I experienced a small explosion sound from the engine followed by a puff of very black exhaust. The engine then was stuttering a barely able to idle as though it wasn't running on all cyliders. The pop was preceded by a whining sound that that sounded like something overpressuring.
Engine: Mercruiser D-tronic 7.3L (300 hp ) diesel
Details:
I had been running at 2900 rpm for about an hour and a half until the sun came up and then pushed the rpm up to 3600. It ran for about 20 minutes after increasing the throttle and then I heard an overpressuring sound come from the engine so I throttled back and it ran rough for a second and then was fine. Then I ran again and about 10 minutes later I heard the overpressuring sound again followed by an immediate pop (explosion) sound and black exhaust billowed out. The engine then stuttered and ran rough at idle as though it wasn't firing on all cylinders. I checked everything I could think of. No fluids leaking out, no water in the oil, no water in the fuel seperator, and coolant was full. After firing it up a second time it ran just fine. So I kept the rpm's below 3300 for the rest of the day and it ran fine for another 13 hours.
Could this be a turbo problem related to high rpms? The engine is rated for WOT 3600-3800. I shouldn't have been running it there probably, but seems like it shouldn't have caused a problem.
We had some water and crud in the fuel a little bit ago - perhaps its related to this? Injectors?
Thanks for your help.
Details:
