Eastboundndown
- Apr 21, 2017
- 74
So, I replaced the shift cable from merc. 5.7 to outdrive and still same problem, then I swapped lower unit out (with a used one), then I swapped the shift lever out because it seemed a little “sloppy” but nothing. Another merc/alpha boater said it could be a bent or worn shift shaft. Has anyone ever ran into this? Could a bad gimbal bearing cause this? Not sure what to check next?
