I have been looking into my 1988 60 HP Mercury outboard as to why it has lower compression in one cylinder. The top cylinder is at 100 psi and the lower 2 are at 127psi. I popped off the cover to the top of the cylinder water jacket to look around for cracks and I found none. I looked thru the spark plug hole to see if I could see anything wrong with the piston. I didn't find a hole, however I did find a half moon chunk of piston right under the spark plug hole that looks like it has been erroded away. Could this missing volume be what is causing the lower compression. I found a bunch of rubber chunks in the coolant jacket, and I assume this is water pump impeller? Could this motor have been overheated due to a water pump failure and caused this piston to start going? I assume corrective action is to replace the piston and water pump impeller? or can I replace the impeller and run it for a while? Thanks for the input.
Bill
Bill
