ForceEightyFive
- Jun 1, 2011
- 20
My motor ran great all day Sunday on WOT, but as I was pulling it up to the dock to trailer it it cut out on me. Once I got it on the trailer after a few attempts since it kept cutting on me, I pulled the cowl off and noticed the thermostat cover paint appeared to have discolored from heat. Also the thermostat gasket sealant appears to have ran down the head gasket cover. Today, after work I did a compression test on my three cylinder engine and found I had low compression on the #2 cylinder (35PSI). The other two came in at 120PSI. Good spark on all three. Thermostat tested fine. I put in some oil into the #2 and got the same low reading. From my reading this indicates that it is not the rings but most likely the head gasket. Also, if I had holed the piston I would have zero compression, right? Any comment would be appreciated on what I should do. Thanks you.
