low compression 60 hp johnson
lonecow69
my compression on my top 2 cylinders is 120, while my bottom is 60. will I damage the engine if I continue to run this way until I can get it in the shop? What do you think the problem is? I was running great and suddenly lost a lot of power. It seems to run good, but the power has been greatly reduced.
S.T. Marine
Re: low compression 60 hp johnson
Do not run it anymore. You still might have a usable crank but if you continue to run it you may screw that up also. The cyliner is probably scored due to not enough oil. Is the motor oil injected?
lonecow69
yes it is oil injected. when I remove the sparkplug and turn it over, it does move up and down.
