Low compression on all cylinders
Mrfixit290
I have a 1975 Mercury 1150 115 hp, the previous owner claims in was running 1.5 years ago when he parked the boat. I just did a compression test and all of the cylinders were between 72 and 85 psi. Should I try something like ring free or what should be the next step? I am wondering if I should get another engine or continue trying to fix this one? Thanks in advance!
The Force power
I would RE-check the compression-readings with a different gauge. (your readings are too low)
Run the engine & check
MPrimeaux
I have the papers where the previous owners of both of my older mercs had the compression checked at a shop and tested waiver 100psi. Both of them run. I got less than 65 psi on all cylinders of my 650 and about 75 psi on all cylinders on my 500. I’ve also tested a 6hp evinrude at 45 psi on both cylinders and a 5 hp honda four stroke at 85 psi. All with the same el-cheapo amazon special compression gauge. I’ve tested the actual gauge with my air compressor regulator and the gauge reads accurately. I suspect there is something going on with the hoses or seals to my tester, but for whatever reason it doesn’t read accurately. My point is, ALL of the engines I mentioned run well and NONE of them are hard to start. May want to verify those readings with another gauge before you do anything to your engine.
MPrimeaux
Also...did you open the throttle all the way while testing?
Absolutely no need to open the throttle on a 2 stroke to get a good compression test.
