Re: low compression on one cylinder
Thumpbass................ I was affraid of that man. I really feel for you. But don't get discouraged. It's hard not to, I know. But keep your head up. Judging by your report on the compression test, it looks to me like you still have decent compression on the other three cylinders. That #3 cylinder is a little questionable though. A good honing and re-ring might just bring that back up where it needs to be. Just to let you know, mine did the same thing. My #1 was toasted also. But you know what, it really isn't that hard to repair the damage. It just takes some time for us newbies. I went all out when I rebuilt my 140, and it did cost me quite a bit of money, but you can re-use some, if not most, of what you already have and get through this pretty reasonable I think. I just opted to go all out because I planned to keep mine for as long as it will hold together. I would be willing to bet you have a considerable amount of carbon build up, as these crossflow motors are bad for that. I wish I would have know this beforehand. I'd have done a decarb and ran seafoam religiously!! That #3 piston probably has stuck rings from this carbon build up, hence the lower compression on that cylinder. I know you already have the OEM Service Manual, so no need in suggesting that again........ d
........... Read it, and then read it some more to familiarize yourself with what your looking at. Popping that head off is no problem at all. It only takes a few minutes to do. The head cover can come off later. I don't know how much help I can be to you, but I'll help where I can as I'm sure others will likely jump in and rescue you as well. Your in good hands. If/when you disassemble, be absolutely certain you keep EVERYTHING in little baggies and marked so as to reassemble the pieces of the puzzle EXACTLY as you removed them. This can't be stressed enough. If you need boring, and don't have a reliable shop in your area, Dhadley suggested Mar-Fab to me. I can give you their address and telephone number so you can talk directly to them. Very very nice people to deal with! You can also buy whatever parts you might need from them. Go ahead and pop that head off and let's see what we're looking at. I'll cross my fingers for you, maybe it IS just a head gasket. Get back with us on this......................... ALAN
