low compression
Robert Baker
low compression on back cylinder.1995 750 STS Kawasaki jet ski .how bad will this hurt, shorterm
SpitAndDirt
Are you still wanting to ride it with low compression? I wouldn't, the damage is done, and you only make the front cylinder work harder. How much difference is there between cylinders now?
Robert Baker
I just got the jet ski in a trade. I was told it was locked up but that was not the case.The compression was 130 on the front & 30 on the back.
Robert Baker
I was thinking if it would run long enough to check for other problems,so I could fix them while it was down
sixfigures
hmmmm 30 I would pull the head and take a peak before spending one cent on it.
jafo9
running the ski is a bad idea. you currently may be able to get away with a simple fix, if you run it, you will likely make it worse. pull the head and take a look.
