low end power loss 150 blk max
blwood11
any suggestions on where to start looking for prob. leading to no low end power in my 96 black max? runs fine once cleared out but cant hardly get kids on tube on plane now. use to jerk skiiers up with no prob? currently pre'mixing at 50;1 using ngk bu8h plugs.
j_martin
Re: low end power loss 150 blk max
Start with compression.
How does it idle?
Barnacle_Bill
May have some trash in your low speed jets. Also check all the fuel lines and especially primer bulb for cracks in the rubber and loose fittings.
blwood11
idle is good? prob better than previous although have never thought it was awsome. as for the fuel line and primer bulb, i purchased new one today and will try this weekend. thx for the reply by the way i do remember from older boat from the past that even though the bulb pumped tight it can b bad.
