hi hope some one can help,afriend has a merc 454 magnum 7.4ltr bigblock,year 98 or99,fuel injected motor, fitted fuel pressure gauge to fuel rail ,fitted a new pressure regulater to rail,at idle reads 20psi,bring the rpm to 2000 and it sits at 15psi,remove the vac hose from regulater at idle and pressure goes to around 30psi,if he blocks the return line it reads full pump pressure 80psi,any help would be great,thanks john.<br /> john_ellis@clear.net.nz
