scrubby1212
- Jul 6, 2004
- 5
e25tecte <br />e0268141<br />its an 1983 electric start 25hp evinrude<br />starts fine runs fine after u past 1/4 throttle into full throttle.but low speed miss <br />changed plugs cleaned carb took a different coil (its the top hole with the problem) didnt seems to make a diff.95 psi compression in both holes.seems to have good spark but wont run very long with the bottom wires off.will run just fine with the top wire off. i havent pulled the fly wheel off yet was trying to avoid that but will if i have to.all grounds look good havent tested volt readings on any thing yet need to get the book first.
