low power output on 87 50hp merc
Rob DeHaven
i can not seem to get things adjusted to get the motor to open up. i use this boat mainly for duckhunting and right now it is annoying to only seem to be getting half the performance i should be. last year i did let it set a little long and when time came to go hunting the motor would not open up at all. i contacted my mechanic who was closed for the season and he said to open up the carbs and let it clean itself out. well it opened up and things got better. i don't think i ever got it set back just right but things were pretty good. now this year i did a better job of having it ready for the season and things were alright at the begining but have gotten worse. i have tried adjusting the carbs while running down the river with no success. i have checked compression and spark and they are both fine. i feel that it is the fuel pumps or carbs. the fuel pumps are on the carbs. do you have suggestions on which one it might be or if you think it might be something else? are there any test i can try?<br /><br />thanks in advance,<br /><br />h
Solittle
Re: low power output on 87 50hp merc
What you have described points to crud in the carbs. Time for a rebuild.
