low rpms on 85 hp force
joebob23
I have a 16' maxum that was taching @ around 5000 then suddenly lost power at WOT and now gets only 3500 on a good day. used to pull a tube and rider with 3 others in boat now won't even pull tube with just driver. 120 lbs on all 3 cylinders for compression. fuel ines clear and pump works fine. any help would be appreciated. Idles kinda rough but runs smooth at 3000 rpms. top cylinder plug kinda black.
jerryjerry05
Re: low rpms on 85 hp force
Do a spark test.then pull the diaphram and see if it's OK.The vent line and squeezie check them too.J
jerryjerry05
Change the plugs.Then do another compression test.I had a bad head gasket and it still had good compression.The warmer it got the more it leaked.J
